Northwest Members WA, OR, ID, MT, WY, SD, ND
Z28 has a broke ass!
Old 07-19-2005, 06:34 PM
Tranzor's Avatar
Default Z28 has a broke ***!
Suspicions confirmed after a phone call from Ellis... tore 2 teeth clean off the spider gears of that Eaton HD differential.
I know I ain't putting another one in there... one good hard launch on slicks screwed that sucker all up... hell the slicks didn't even stick, they spun and the damn thing still gave up. So I'm sitting here thinking... what would Sardog do? Hmmm... Man up and stick a locker in that sumbitch!
Of course, I'm not that extreme really... so I'm thinking I may go with the Auburn or Detroit electric locker if I can afford it. If the finances won't allow, I guess I'll just have to say f*ck it and do it the Sardog way... I suppose I can live with some clunking in the rear end if it means it won't break again.
Old 07-19-2005, 06:57 PM
slowpokez28's Avatar
Ouch My car's rearend is loose to andc could give at anytime...I hope it make it thru the summer. Not sure i will be hiiting it hard after the cage goes in. it just really has to live thru 2 race days and back home.I feel for ya man do a sardog way, and save up some coin for what you want.
Old 07-19-2005, 07:00 PM
sardog46's Avatar
Well I guess you already know what i would say
the detroit is not that bad. It defenatly takes some getting used to. Makes alot more noise on street tires than on slicks. I never ever noticed drivng on slicks.
One thing you will never have to worry about it again......trust me
The only thing I don't like about the electric lockers is it is one more thing you have to worry about breaking. It would really suck to be about 60ft out and have it unlock
Jason this is where it starts to get tough, Now comes the decisions that start to comprimise daily driver duty.........Just like your next step of a cage
But like you have already said you know what I would do
Old 07-19-2005, 07:02 PM
Tech Addict
Rokko's Avatar
screw it, just put a spool in there.
Old 07-19-2005, 07:21 PM
Tranzor's Avatar
That's right, if I do things the Sardog way its gonna be a locker all the way... then some weight reduction, some bigger slicks, a hefty shot of nitrous and a nice truck to tool around town in instead of the Camaro.
Old 07-19-2005, 07:38 PM
sardog46's Avatar
AMEN Brother..........Another one has seen the light
Old 07-19-2005, 07:40 PM
Racehead's Avatar
That sucks about the spiders Jason, but at least by the time you have it together again it'll be stronger than ever. I keep wondering how long my 8.5" 10 bolt is gonna last .........
Old 07-19-2005, 09:47 PM
WAHUSKER's Avatar
So is the 12 bolt a c-clip rear end? Meaning I wonder how close you came to having it pop an axle out on the road/track.....and you might consider the Trac Loc. Supposed to be about as good/strong as a locker without the issues. Talk to Ellis & Dan.
And I apologise sardog. I was going to call you but this little incident happened on the home front & I just now thought about it. Tomorrow?
Old 07-19-2005, 09:52 PM
TwoFast4Lv's Avatar
The Rear end uses Ford bearings. Two Clean broken teeth alog with some other stuff. Jason should be getting a call from Dan tomorrow so they can deside on a direction to take
Old 07-19-2005, 11:44 PM
Tranzor's Avatar
That'll be the moment of truth... continue to be equal parts street and strip, or start moving toward the mostly strip side.
And I'm actually kinda anxious to find out when you look at the clutch... I'm just hoping that it dragging didn't cause any damage to it.
Old 07-20-2005, 12:54 AM
Rickerbucks's Avatar
One of the BIG compromises for daily driveability is the Sponh Torque arm. Man, I feel EVERY vibration of the 12 bolt through my butt. (so to speak)
Old 07-20-2005, 01:42 AM
Tranzor's Avatar
Heh... I have so many rattles and vibrations I'd hardly notice a change in torque arms. I'm sure I'd notice a locker though... that's really gonna effect how I view the streetability of the car.
Old 07-20-2005, 08:18 AM
WAHUSKER's Avatar
Yeah, with a locker you can expext everytime you go around a corner the cops will notice you. I still remember the time I got pulled over for squealing my tires going around a corner at 5mph. I told him about the square spider gears I was running and popped my hood & showed him the monster I had, and he let me go.
Old 07-20-2005, 09:55 AM
sardog46's Avatar
hey jason, If you want to know the low down give me a call and I will tell you my experience
Old 07-20-2005, 11:45 PM
TwoFast4Lv's Avatar
Well we are still looking but it looks like new posi,Locker or spool are the only options
Old 07-21-2005, 12:28 AM
Tranzor's Avatar
Well, I'm definitely leading toward locker at this point... I do believe that Detroit Locker is the one that Moser uses now as their locker of choice. Also, I'm thinking the 4.30 gears will be the ring & pinion choice as well, since I'll be switching to a 27" tire at some point...
Old 07-21-2005, 11:36 AM
sardog46's Avatar
That would be a good gear choice jason, I would also look into 4.56-4.90 with a 28 inch tall tire that is a great n/a combo
Old 07-21-2005, 12:10 PM
esoteric's Avatar
Get a 9" and be done with it.
Old 07-21-2005, 12:18 PM
Tranzor's Avatar
Eh... 12 bolt with a locker & c-clip eliminators, or 9" with a locker... it'll do the same thing. Except for the ease of gear changes, of course.
Old 07-21-2005, 05:19 PM
Tranzor's Avatar
Ok... well, looks like a Detroit Locker and 4.30s for me. Got a call from Dan and Ellis, sounds like that's the best thing, so that's what they're gonna set up for me... I may not like it on the street too much, but at least I won't have to buy a new Eaton or Auburn diff after every race.
