Doing Berger panel, few questions
I will be removing my "CAMARO" panel this weekend to fill in the letters and paint it flat black. My questions are:
Which body filler do you use to fill in the letters and where do I get it? I know I need to sand it all down to make it rough, I just need the product.
Which type/brand paint did you all use? Did you primer, clearcoat, or wetsand?
Thanks!
Mitchell
Thanks!
Mitchell
i used some cheap autozone filler, might have been bondo. The blue/lightweight kind
works alot better than the normal cheapo filler with the red hardener
i also used a dremel to sand/scuff the letters. While i was at it, i cut the keyhole off, and glassed that shut
