Dynamometer Results & Comparisons - Mods and Messed Up HP? (Bad car?)
View Full Version : Mods and Messed Up HP? (Bad car?)
fasttagurl
07-20-2005, 08:18 AM
High Flow G2 Airlid
Ported MAF/TB
Crane "Z" Cam with .585 lift, (218, 224)1.8 rockers, double coil valve springs
TCI 3500 Stall Converter
Pacesetter LTs
No Cats
TSP True Dual Exhaust 3"
Dyno'ed HP:
1) 295 before mods
2) 357 after mods and tune
3) 329 after 2nd tune
With everything I should be turning around 385-390, but no luck. Just thought I could post here to see if someone has a different/close combo to mine.
iamsickofitall
07-20-2005, 08:49 AM
take the car to a real tuner
nasty99WS6
07-20-2005, 09:07 AM
High Flow G2 Airlid
Ported MAF/TB
Pacesetter LTs
No Cats
Dyno'ed HP:
1) 295 before mods
357 rwhp with a small cam and exhaust as your only power mods is not bad for an a4. why did you try to tune it again, did you add a different mod?
lilbuddy1587
07-20-2005, 10:25 AM
High Flow G2 Airlid
Holy valve float batman! .585 lift ANDA 1.8 rockers..... I hope your springs arent ready to grenade..
LETZ RUN
07-20-2005, 02:24 PM
do you have an ls6 intake?
fasttagurl
07-20-2005, 04:10 PM
No LS6 Intake, going for an LSX. My cam was not .585 before the rockers, the rockers made them a .585 lift. So by the sound of it you all think it is normal, right??
lilbuddy1587
07-21-2005, 12:12 PM
Very normal, especially with the verter and the ls1 intake.
