Cluster Problem
Old 07-21-2005, 06:59 PM
DynomaxTA's Avatar
Default Cluster Problem
I have a 99 trans am, and every time u hit the gas hard, or brake hard, the clusters, tach, speed and everything reset real quick, radio turns off to. I have been hearing that it might be a bad ground, but just wondering if anyone had any ideas
Old 07-21-2005, 10:23 PM
slow's Avatar
check your battery mount.
I have seen where when you gas it hard, the battery rocks into the AC canister, and the + terminal will arc on the bracket/canister. This will cause the cluster to act weird, the car may stumble too.
Ryan
Old 07-21-2005, 11:46 PM
patSS/00's Avatar
I had a similar problem with another car, turned out to be a poor battery terminal connection.
Old 07-22-2005, 12:05 AM
DynomaxTA's Avatar
Default thanks
alright, thanks for the info
