How will my car run with 28" tires and no tune?
Old 07-22-2005, 03:11 PM
TS6
TS6's Avatar
Default How will my car run with 28" tires and no tune?
I was thinking about going with some 28" slicks and I know its going to mess with my abs but if I don't correct it in the pcm how bad is it going to run? Will it mess with my shift points? I know the speedometer will be off. I'm only going to use these sometimes, but my other tires are 26", and I don't have a way to tune the car. It was tuned on 26" tires. Thanks for the help!
Old 07-22-2005, 03:53 PM
SSpdDmon's Avatar
Chances are it'll think you're going slower than what you really are and may bounce off of the rev limiter in the WOT upshifts.
Old 07-22-2005, 05:24 PM
P Mack's Avatar
I don't think it will mess with your shift points. Your shift speeds will be off but your speedometer will be off by exactly the same amount.
