EFIlive V6 and/or LS1edit work with LC-1??
Old 07-22-2005, 10:44 PM
Classic's Avatar
Default LS1edit work with LC-1??
Just wondering if you could set up the newest version of Edit to log the data from the LC1. And if so -- how would you go about doing that?
Thanks
Old 07-22-2005, 11:24 PM
horist's Avatar
only way I can think of is the way people used to do it before there were scanners out there w/inputs
People used to hookup the 0-5 volt signal to one of the AC sensors (effectively disbles your AC) I just got home and am heading to bed in a few... but if no one finds it for you (or you don't find it via search) tonight I"ll try to find it tomorrow
It's not the best way but I believe it's the only way w/edit ... not sure if the edit "scanner" can log the info you'll need... EFI Live V6 will definetly do it though (you removed from the title so not sure if it was a mistype?)
Old 07-23-2005, 10:12 PM
Classic's Avatar
sending you a PM
