nitrous line run insie of car, or outside of car?
taking opinions on whether to run the nitrous line inside or outside of the car. i was thinking to run it straight down out of the rear fender and then run it up to the engine bay. possibly with the fuel lines, or possibly inside the frame rail.
Lemme know what you guys think.
Thanks
Louie
Thanks
Louie
Originally Posted by code4
I did outside since some tracks won't let you run with the lines inside. So I figured why not do it right the first time.
Thanks
Louie
Restricted User
I'm going to run mine under the car. for where it goes up over the axle, I'm going to weld a formed pipe with the undercarridge to go up over the axle to slip the hose thru so the hose will stay up away from everything. it should be interesting when its all finished.
