Voltage, can tuning affect this?
Old 07-23-2005, 09:16 AM
Michael Ozorowsky's Avatar
Default Voltage, can tuning affect this?
May be coincidence, but after I converted A4 to M6, I can't use my AC. If I turn my AC on, after a few minutes, SOMETIMES doesn't do it at all, but randomly my voltage will drop all the way down to the point where the car dies and I need a jump start. I had a VERY good mechanic friend check it out, and we swapped the alternator AND battery. DId load test, the load tests are fine at idle, but after driving around, everything starts dieing out. What could be going on? I need a direction, so PLEASE help. Could a tune affect this somewhow?
Old 07-23-2005, 09:22 AM
Moderator
jimmyblue's Avatar
My A4 did this from new but after I raised the idle RPM
it hasn't. I believe it's an alternator / regulator problem.
The field current has to run higher to make demanded
current, when shaft RPM is less. This puts max power
dissipation onto the field current driver in the alt regulator
and I believe it goes into some sort of thermal limiting
(because I only encountered this on hot days, max
electrical load).
You might want to check the load-bump idle airflow stuff,
as well as raising the base idle RPM to some more stable
(i.e. more room to bounce, before dying) value.
Old 07-23-2005, 09:29 AM
that is when I notice this too, here in FL on HOT days, max electrical load. Can you tell me in IDIOT terms where to find these settings? Also HOW to adjust them.
My idle with ac on right now is 950rpm (Big cam)
Old 07-25-2005, 01:08 PM
Also, when my electrical system starts acting up, engine temps start getting HOT like 230 degrees PLUS, dunno if this is related somehow. This all ONLY happens when AC is on. I can't figure it out.
Old 07-25-2005, 02:52 PM
Moderator
jimmyblue's Avatar
Here are some of the "*****" I was talking about (the
view is probably different, these are off beta HPT2.0
but the stuff is there in earlier versions).
Attached Thumbnails Voltage, can tuning affect this?-bumpac1.gif   Voltage, can tuning affect this?-bumpac2.gif
