Timing Tuner & LS1 Edit
Old 07-24-2005, 09:39 PM
A Mustang's NightMare's Avatar
Default Timing Tuner & LS1 Edit
can I use the timing tuner even if I have ls1 edit?
I want to do timing change when I increase nitrous
Old 07-25-2005, 03:34 PM
Matt@HSW's Avatar
Yes. That's the beauty of the timing tuner. You can bump up your NA timing with edit (or you could use the timing tuner to add in timing) and then when you spray it it'll retard timing.
Matt
