true duals
true duals
i jus ordered pacesetters lt and im set on true duals n sweet thunder mufflers.. what sweet thunder muffler should i get? and can someone post a good pic that i can show a shop of how it should look like. thanks
depends what you want... the longer, the quieter and obviously more expensive. stainless is nice but i wouldnt go stainless unless the rest of the system is going to be stainless. you'll probably want the 3inch inlet/outlet (even though the core is only 2.5) or if you do the whole system in 2.5, you'll want the inlets and outlets to match. theres a really good picture of an over-axle setup on the site, but you probably want dumps?
