Pontiac GTO 2004-2006 - Headlights staying on
Jupiter-Dearborn
07-26-2005, 07:59 AM
Has anyone else had problems with their lights staying on when the switch was in the automatic position? My battery has already died once due to this and today they stayed on for the third time in 3 months. Has anyone heard of a TSB on this? I took it to the dealer the day after the battery died and they colud not "reproduce" the problem.
Any info would be a great help.
thanks- :bang:
Brains
07-26-2005, 08:29 AM
Mine stay on for 60 seconds, but that's what its set to in the cluster. Heck, if I leave the switch at "ON" it'll shut 'em off too. Seems the only difference between ON and AUTO is in the ON position it ignores the ambient light sensor. If you're killing the battery, it might not be the headlights -- you could have one of the bad batch of batteries. Mine has already been replaced under warranty.
you2slo
07-26-2005, 08:30 AM
You are not alone. Mine have done the same thing a couple times. I noticed after about 15 minutes, so the battery has yet to go on me.
dubrado
07-26-2005, 01:51 PM
what's wierd is that my stereo will turn on and off w/o me having to put my keys in the ignition at all
i closed and open the door and it won't turn it off
Irakz
07-26-2005, 02:53 PM
My lights have stayed on twice now. I caught it though only after a few minutes so it has not caused me any problems.
I also noticed the ability to use the stereo without having the keys in the ignition. I left it on and waited for it to shut off on its own but it never did...I thought it might be on a timer like my old ta.
Anyway just wanted to say I have had similar problems.
Brains
07-26-2005, 03:57 PM
That radio staying on without the keys (if you turn it back on after pulling the keys out) is a feature (check the owners manual).
BUT ... If you have the car running, shut it off, pull the keys out and the radio continues to play without hitting any buttons, it means the side bar in the ignition cylinder didn't fully release -- so it thinks the key is still in. I've had this happen a couple times, just stick the key back in and pull it out again.
Irakz
07-26-2005, 05:30 PM
I have never had the radio stay when pulling my key out. I just think it is odd that the car would not turn off the radio even if it is a feature.
Brains
07-26-2005, 05:52 PM
It'll turn off, but you can manually turn it back on... Try it :)
dubrado
07-26-2005, 06:13 PM
just making sure it wasn't just mine lol
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
