How do you guys rough in a VE table
Old 07-26-2005, 02:28 PM
7 Second Club
Phil99vette's Avatar
Default How do you guys rough in a VE table
How are you guys roughing in a VE table on a new tune? Are you guys using another table similar to your current setup or are you starting from scratch?
Phil
Old 07-26-2005, 02:39 PM
horist's Avatar
I just start from scratch, log and make the changes like normal... Since no 2 cars are the same, I prefer not to copy someone elses VE table ... especially since it doesn't take long to get the table pretty well dialed in
Old 07-26-2005, 02:44 PM
7 Second Club
I have an auto that is a PITA to get it to idle. No matter where we set the numbers it never wants to idle. Any ideas?
Phil
Old 07-26-2005, 06:49 PM
RedHardSupra's Avatar
depending how ridiculous the setup is. if you're tuning something truly ridiculous, you know you can cut like 30% off the first 3 columns, and start adding a nice chunk >4krpm. from that, just scan, adjust, repeat. starting off with something closer to your target just saves time, that's all.
Old 07-26-2005, 06:53 PM
Bill Bowling's Avatar
Talking
I am using a LC-1 WB and FlashScan's Autotune. It is really easy.
Bill
Old 07-26-2005, 08:53 PM
torchedZ's Avatar
Bill
After Autotuning can you use the MAF again or do you have to run mafless with that tune?
Old 07-26-2005, 09:03 PM
Bink's Avatar
You can go back on the MAF.
You will need a Wideband O2 to use their BEN Factor "AutoTune".
In fact, with EFILive's software, you can use a custom map in their scanner and copy /paste in a new MAF table - after you're satisfied with the new VE table.
They have really simplified the whole VE tuning process.
FWIW.
Old 07-27-2005, 11:05 AM
TAQuickness's Avatar
^^^ Agreed.
To rough it in, I would use a WB, force OL SD, scale the whole VE table up 15%, command a 14.63 AFR for cruise and decel, and 12.5 for WOT. Then just go from there.
