TPS sensor?
Old 07-26-2005, 09:11 PM
1ORANGEWS6's Avatar
Default TPS sensor?
I just did a H/C swap on my car now my car is throwing a code. When I scanned the car it had and error for the TPS sensor lower voltage. What would make the sensor read low voltage?
Old 07-26-2005, 09:23 PM
slowpoke96z28's Avatar
faulty connection. check for voltage at the connector and check for resistance on the TP sensor itself.
Old 07-26-2005, 09:27 PM
1ORANGEWS6's Avatar
If I do an idle relearn it will act fine for about a day then throws a code again. It really jacks with the idle when it screws up. I will try to borrow a meter to check the voltage.
