Anybody replace their dash security LED???
Looking to put a different color in and wanted to know if anybody's done it and any specifics. Thanks!!!
Joe
Joe
re led
I replaced mine, not too bad of a job, didn't even have to take the a pillars off.
You can pry the center of the dash to get enough access to the led. You have to use a soldering iron to get the factory led out. Once that is done pry out the guts for the plug and drill hole for new led. the housing for the factory led unscrews from the dash. I reused this piece for my blue led. Green wire will be positive and black negative.
