28.8# injectors ok with 150 wet shot??
Originally Posted by 2 Stroke Racer
I currently have 100 dry, going wet, will 28.8 be o.k. with 150 wet??
Thanks in advance!
Thanks in advance!
I'm running 150 wet and just pulled 524 rwhp on the dynojet. This was with stock injectors. The A/F ratios were ok so there's no need to upgrade the injectors. I have an inline fuel pump that delivers 255 lph though. You probably need to upgrade your fuel pump....
It would seem that way based on RWHP, but the overall RWHP is skewed by the nitrous system adding fuel. Now the fuel pump is a different story, but the injectors are only supplying fuel for 350 RWHP in your 500 RWHP scenario.
Hope this helps.
Hope this helps.
