Drag Racing Tech - Fitted my W's today
SMOKIN01TA
07-28-2005, 07:42 PM
because everyone that ive seen with w's had talked so much about the cutting and clearancing to fit even with stock fat brake rotors i went ahead and got a set of 6.5 backspace rims to go with my ultra thin strange rotors and they fit easily, honestly, just by looking on the inside of the fenders i have enough room to probably get away with a 7.5 backspace but it would be tight, but i dont think it would rubb. ima run with the rims i have till i have time to swap them over and try the 7.5's that my old slicks are on. i guess the massive beating and clearancing i did for the 325 radials was enought for the w's because it looks like the radials are actuall wider than the w's, just not as tall :)
ima try the new combo tomorrow night and see what happens :nod:
I'm a little confused by the 'thin' Strange brake rotors comment. I had to use the spacers to space the bearings out and the width of the spacer + the strange rotor thickness was the same as the thickness of the stock rotor so nothing changed here with the Strange brakes.
SMOKIN01TA
07-28-2005, 07:52 PM
well, all i can say is that i have to run spacers on my radials now and with the stock brakes i could barley get by without them :confused:
did you have to use spacers behind the bearings with yours? I was concerned about the thinner rotors as well since my 28s were pretty close on the inside with the stock rotor but I measured the thickness of the spacer and the thickness of the strange rotor and it was exactly the thickness of the stock rotor. Dont know if that was by design or just the way it turned out though ;)
MADMAN
07-28-2005, 08:50 PM
Damn Rodney SLOWING THE CAR DOWN????????????????
SMOKIN01TA
07-28-2005, 08:55 PM
shouldnt be, depending on what im crossing at tomorrow night i may have different gears for b/g tho. none of us m6 guy seem to get out of the 1.401 60's and everyone that has gone to w's droped the 60's nicely, ima mess with it all tomorrow night, shocks, pressure and all so it dont bogg and leaves like a mofo and see what kinda trap rpm im at. ;)
MADMAN
07-28-2005, 09:03 PM
MMMMMMMMMMM let me know
Magnus
07-28-2005, 11:51 PM
Dude, grow a sack and put on some 30x15x15 ET Drags on the car..
Only little girls run 28x10.5W's..
I'm gonna run monster truck tires on my car per madman's recomendation. ;)
Edit:
Rodney, I found the tire you should be running on summit.. 32.00 x 14.50-15
You can thank me later.
SMOKIN01TA
07-29-2005, 12:37 AM
Edit:
my gears would have to be like 6.40's or something so tinny it would break on every launch :devil:
gator's 99TA
07-29-2005, 09:40 AM
then run a 2.5 ton axle! duh!
Pro Stock John
07-29-2005, 10:07 AM
6.5 backspace? Do they stick out like 2 inches?
Fireball
07-29-2005, 10:15 AM
mine wouldn't fit without some cutting (on a 7.5 BS rim)...I didn't have to go as extensive as I did...but I felt safer than sorry. You need room for when the tires wrinkle and flex left to right some IMHO
SMOKIN01TA
07-29-2005, 11:08 AM
na, its bout even with the top of the fender, but i would like to tuck it that extra inch in the next week if i have time, if not youll see what it looks like ;)
SMOKIN01TA
07-29-2005, 11:10 AM
yea, i already did some cutting to the inside bottom corners and on the inside fenders where the humps are in the metal and stuff, so i probably would have been ok :mad:
Pro Stock John
07-29-2005, 11:35 AM
Is the rearend housing narrower than stock? I would swear that 6.5/stock housing length sticks out past the body.
SMOKIN01TA
07-30-2005, 01:12 AM
it sticks out a tad lookin at it, ima try my other rims when i get a chance and see how it fits with them, i hate wasting that open space between the tire and the fender :(
1fastWS6
08-01-2005, 01:57 PM
PSJ,
Here's a 26x10 ET Drag on a 15x10 with 6.5" bs. The rim is about even with the outside of the quarter panel on a stock housing length. A 10.5W probably only sticks out 1/2" past that.
http://community.webshots.com/photo/80440351/188005760uUoGhA
