Shift Light
Shift Light
I was wondering if I am able to hook up a shift light while using my stock tach. I think it would look better than adding another one? If so how would I go about hooking it up?
SSU's Drunk Typing Whore
Yeah I just hooked one up the other week. I went with the raptor shift light, here is the website...http://www.raptorperformance.com/. Here are a bunch of pics as well/install procedure...http://www.raptorperformance.com/Che...let_camaro.htm. I hope that this is what you are talking about .
yeah I use the harlan with my stock tach. The stock tach lags a little but I think the actual signal from the PCM is pretty accurate (and therefore the shift light should be). I dont think an aftermarket tach is worth it, all you need is a shift light. Concentrate on driving and when you see the light, shift. thats the best setup IMO.
and personally big tachs on the dash look dumb unless your car is a drag car. I put my shift light in the AC vent, so you cant see its there untill it comes on.
You can use this write up - http://www.installuniversity.com/ins...sity/index.htm. Or the write up the I posted about 6 posts up.
liqour enthusiest
i think you splice into a wire on your ecm, i saw the directions on installuniversity.com i believe.
