Sponsored by: DashLynx
head light!!!!
Old 07-28-2005, 11:54 PM
xx9666xx's Avatar
Default head light!!!!
guys im ready to change my front lights to an exnon lights,but i don know what brand shall i go with cuz its comfusing there is alot of brands and im worried about their look,im looking for the ons like bmws,and ideas???
Old 07-28-2005, 11:55 PM
xx9666xx's Avatar
money is not a problem.....
Old 07-29-2005, 10:04 AM
abadss's Avatar
as in BMW's with the halo's? or HID's? or are you just replacing the bulbs? be a little more specific, or try the search.
Old 07-29-2005, 02:36 PM
xx9666xx's Avatar
i cant replace the bulbs for the head light i have to change the light,so i need to buy the lights
Old 07-29-2005, 06:22 PM
Copy & Paste Moderator
VIP1's Avatar
Fixed Headlights:
https://ls1tech.com/forums/showpost....18&postcount=2
(Contains many links to other threads)
https://ls1tech.com/forums/showthrea...3&page=1&pp=20
Here is a thread where someone install HID projectors in the pop-up housings:
https://ls1tech.com/forums/showthrea...ight=projector
http://firehawk.jonbroomfield.com/hidinfo/
In this thread there is a discussion about this and a link to a thread on another board with instructions on converting a sealed beam bulb into a conversion unit to allow the installation of bulbs like the Camaro and most newer cars. Check it out, he shows how to disassemble the sealed beam bulb to allow the instalation of regular bulbs.
https://ls1tech.com/forums/showthrea...ht=sealed+beam
Here is the link specifically:
http://www.fullthrottlev6.com/forums...6994#post36994
The thread moved.
Here is the new link:
http://www.fullthrottlev6.com/forums...ead.php?t=1545
Here is how I did it on my 2001 Formula:
(Slight variation on the above installation)
https://ls1tech.com/forums/showthrea...hlight=housing
Unfortunately, they eventually had standing water in them and a loose connection caused the stock driver's side bulb connector to melt. I now have Hella 90mm H9 projectors instead.
Here is the same idea for the 93-97 Camaro:
http://performanceworks1.com/headlightmod.htm
Good thread about HID on Firebirds:
https://ls1tech.com/forums/showthrea...&highlight=hid
(pretty much covers it)
More threads about HID on Firebirds:
(check out my posts...plenty of links to more threads)
HID projectors in a Camaro:
https://ls1tech.com/forums/showthrea...ght=camaro+hid.
http://community.webshots.com/album/116863233uyEamc
Happy Reading.
EDIT 12/20/2006
More links on Projectors and HIDs:
https://ls1tech.com/forums/appearance-detailing/623222-ok-what-s-best-hid-s-out-there.html
https://ls1tech.com/forums/appearance-detailing/627116-2002-trans-am-headlamps-help.html
https://ls1tech.com/forums/appearance-detailing/613458-post-up-your-hid-s.html
Quick Reply: head light!!!!
