Northwest Members - check out this engine!!!!
sidewayz28
07-30-2005, 10:44 PM
ok well i need to know what pulley is directly under my A/C pulley...because on monday im deleting the A/C and i need to know how big of a belt im going to need because as far as i can see the belt thats connected to the AC is also connected with 2 other pulleyssssssssssss check it out!!!!
oh and thats my gorgeous car!!! :angel: :cool: :hail:
iansane
07-30-2005, 11:56 PM
Power Steering pump?
sidewayz28
07-31-2005, 12:33 AM
YES YOU ARE CORRECT!!! YOUVE JUST WON THE GRAND PRIZE: A MILLION DOLLARS!!!! no but yah your right thanks.....ummmm any clue as to what size belt i would need if i deleted my ac?
sidewayz28
07-31-2005, 12:35 AM
i guess i got just always ask at the local car parts store
Racehead
07-31-2005, 12:37 AM
Just wrap a string around the pulleys on the path that the new belt is going to take then measure the string. Quick and easy :)
sidewayz28
07-31-2005, 12:42 AM
uh you are the smartest person i know
sidewayz28
07-31-2005, 12:43 AM
all im going to need to have is a pulley from the water pump??? crank??? center pulley?!?!? dont know the name to the power steering pulley correcT?
iansane
07-31-2005, 10:10 PM
Well if you don't have your smog pump then you'll just have the alternator, PS pump, crank (the one down at the bottom center), and water pump. Just remember to route the belt so it has good surface contact on all accessories. :)
sidewayz28
08-02-2005, 05:34 AM
i decided to keep my a/c...i put a k&n filter and dumped some octane booster in my tank and my car feels pretty good right now....and theres a possiblilty my heads could be aluminum...i need to try the magnet test tommorow
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
