brake fluid leak at master cylinder and Brake Booster...but...
Old 07-31-2005, 03:45 PM
navyblue2000's Avatar
Default brake fluid leak at master cylinder and Brake Booster...but...
It only happens when the car is jacked up on the front, driver's side.
I changed my brakes yesterday and noticed brake fluid was coming out of the bottom of the brake booster, where it meets the master cylinder. After I got the brakes changed I pumped the brakes, and no fluid leaked out during the pumping of brakes (had a friend with me). It doesn't leak right now, and like I said it only leaks when it's at such an angle like that.
what could be the cause?
Old 07-31-2005, 06:26 PM
89lx-ls1's Avatar
I would just replace the master. they will leak at the seal in the end of the master between the master and booster
Quick Reply: brake fluid leak at master cylinder and Brake Booster...but...
