Generation IV Internal Engine - LS7 Part numbers and some prices are here...
WoodManZ
08-03-2005, 10:33 AM
LS7 camshaft 12571251 GM list---$166.15 (new part)
LS7 cylinder heads 12578450 GM list $904.11 ea(no valves) (new part)
LS7 Titanium Connecting rod 12586258 GM list-- still not avail yet (new part)
LS7 Intake Valve 12591644 ---101.42(new part)
LS7 exhuast Valve 12578455---101.42l (new part)
LS7 r-sight shield 12574620--GM list --60.74 (new part)
LS7 l-sight shield 12574619--GM list--38.17 (new part)
LS7 Intake manifold 12569011--458.85(new part)
LS7 throttle body 12570790 445.52(same as ls2)
LS7 valve spring 12578457 9.66ea(new part)
LS7 Rocker arm (intake) 12579615 $13.66 ea
LS7 Rocker arm (exhaust)12579617 $13.66ea
LS7 crankshaft 12568820 $1151.52 list
Z06 front fascia 15824768--GM list $745.00 (new part)
Rear 19x12 wheel 88967369 700.68
LS7 Clutch & Pressure plate kit 24233650 $457.86 (new part)
LS7 Engine oil tank 12603281--988.00
LS7 Oil Pan 12596689--559.11
LS7 aux eng oil tnk hose 15210117 116.38
LS7 aux eng oil tnk hose 15210122 122.91
LS7 oil pump 12598212 no info
all prices are temporary of course...
More to come.
Any Requests?
Ron
DanO
08-03-2005, 11:01 AM
Im betting GM is going to make alot of $ with aftermarket LS7 parts..
especially the Titainium Connecting rods!!! (I know im going to buy some)
Mas280
08-03-2005, 11:26 AM
Any news on the ls7 clutch?
John B
08-03-2005, 01:11 PM
Nice work!!!
Any Requests?Yes! How about the dry sump external tank and lines?
Mike454SS
08-03-2005, 05:18 PM
Doess anybody know yet if the dry sump system will work with an older LS1 block?
MM98
08-03-2005, 06:47 PM
Nice work!!!
Yes! How about the dry sump external tank and lines?Here ya go!
-dry sump tank. part#12603281, p&a not yet availiable.
-outlet & inlet cooling line, part#15210122, list $118.
-outlet oil line, part#15210117, list $111
Mike
militant_x
08-03-2005, 07:13 PM
so when does this stuff actually go on sale? gmgoodwrench and gmpartsdirect cant find the number for the cam...
xxxhp
08-03-2005, 07:24 PM
LS7 block?
xxxhp
08-03-2005, 07:34 PM
Just double checking, that price is for a pair of heads, am I right?
Also, would you happen to know the price of the new truck heads (L76?)
93LS1RX7
08-03-2005, 08:17 PM
Nope that is each according to him. That is why he has $904.11 ea with the ea meaning each
mr2guru
08-04-2005, 11:03 AM
bwahahaha captain obvious strikes again! :judge: :jest:
hellbents10
08-04-2005, 11:48 AM
Will the Ls7 clutch work for a Ls-1,2,6.............?
That would be a nice mod/alt. to aftermarket.
mnc2886
08-05-2005, 01:01 AM
I want to know about the block as well.
WoodManZ
08-05-2005, 11:51 AM
The block is not sold as a replacement part. ...yet
Ron
myss2638
08-05-2005, 01:45 PM
I punched in the head # on gmpartsdirect, they are selling them for $630 (each) including shippin. Not a bad price if you can find an intake and valvetrainto go with it.
Hennytime
08-05-2005, 04:05 PM
what are the specs of the camshaft? im hoping it s a little more extreme than tha ls6
JL ws-6
08-13-2005, 10:22 AM
the cam is in teh 230 range, with about 590 lift.
DavidNJ
08-13-2005, 10:43 PM
What about the brakes. Fixed caliper brakes have always been big $$$ (Alcon, AP, Brembo). How much are the Z06 ones and will they fit C6 and C5 spindles and hubs?
Thanks,
David
Z06er
08-27-2005, 05:59 PM
P/N and price for exhaust mainifolds
horsepower
08-30-2005, 02:24 PM
LS7 Rocker arm (intake) 12579617 no info
LS7 Rocker arm (exhaust)12579617 no info
something is not right here....the parts are different. Shoot again :)
NeoPaladin
08-30-2005, 03:30 PM
Sorry, but that actually is correct. The intake rockers are offset on the LS7 heads due to the fact that the intake valves are so large. They have an angle to them. :drive:
horsepower
08-30-2005, 03:34 PM
umm...the LS7 uses two 'different' rocker arms (two different part numbers). One intake, and one exhaust - they are not the same parts.
http://vorlon.case.edu/~aap8/gallery/c6z06media/LS7_Engine_1
badaSS346
08-31-2005, 09:05 AM
What will the LS7 heads bolt up to?
horsepower
08-31-2005, 02:27 PM
confirmed the LS7 rocker pn's today:
12579617, EXH
12579615, INT
leftcoast32
08-31-2005, 03:12 PM
Anyone have a part number for the exhaust manifolds?
slt200mph
08-31-2005, 05:23 PM
The cam is not very agressive..210\230 .591 probably about a 118 LSA..
they left a lot of horse power on the table with that grind..but they have to deal with emmissions, longevity, durability, and driveability being a manufacturer..you can find a lot more cam that that for not much more $$$
If you put a 246\246 .630\.630 on a 112 LSA and set of LTs with no cats and good exhaust and a good tune up the LS7 will make about 625 HP at the crank
Quickin
09-01-2005, 11:47 PM
It says $515.35 for each head.
They will never be able to honor that price unless it a completely bare head maybe.
TUF383
09-02-2005, 05:01 AM
Any Requests? Ron
Injector part number (& price?)
Does anyone know if it is still a Bosch unit?
TUF383
09-02-2005, 05:05 AM
We (Harrop Engineering Australia) are currently tooling up for the LS7 version of our 8 throttle plate Hurricane manifold. (http://www.harrop.com.au/products/intake_systems.html) :drive:
NeoPaladin
09-04-2005, 05:50 PM
Sorry, that's what I'd meant to say. Guess I wasn't clear. :)
guinness2
09-05-2005, 09:32 AM
We (Harrop Engineering Australia) are currently tooling up for the LS7 version of our 8 throttle plate Hurricane manifold. (http://www.harrop.com.au/products/intake_systems.html) :drive:By the way how much is that thing for a ls1 f-body
TUF383
09-05-2005, 05:11 PM
The LS1 cable-pull version manifold, with air-pods, is about US$3,600 including freight to anywhere in the US.
I don't know if it fits under the hood/cowl etc of an F-body ... we don't get them in Aussie. :cry:
guinness2
09-05-2005, 05:55 PM
I'll tell you what send me one and I'll make it fit. The american re-engineering and consultation fee will only be $3600 U.S. :)
CONVERTED
09-06-2005, 03:15 PM
what kind of gains are you getting out of that???
TUF383
09-06-2005, 06:08 PM
We are still tooling for it, so we can't really tell ... but the LS1 version is here (http://www.ls1tech.com/forums/showthread.php?t=350199)
52172
09-26-2005, 09:40 PM
Do the bare heads come with the cnc porting? I doubt it at the 515 price?
slt200mph
09-27-2005, 07:27 AM
If you are talking about the LS7 heads they are CNC ported with a 12 degree valve angle
52172
09-27-2005, 08:07 AM
Yes I am talking about the ls7 heads, but at gmpartsdirects price it is hard to believe the cnc porting is there?
slt200mph
09-27-2005, 09:31 AM
Mass production lowers prices...plus you are not paying the LS1 LS6 LS2 "tax" (inflated prices) that so many vendors have slapped on LS series motors parts for the last few years..it is about time to get some decent pricing on LS series motor parts.. :thumb:
Drewman
11-17-2005, 01:40 PM
Any Requests?
Ron
Bringing this back up to the top. How about the windage tray and the front cover?
rob c
11-17-2005, 10:41 PM
Price of the LS7 clutch/pressure plate and a flywheel (if necessary for the LS1)? Thanks!
Ferocity02
11-18-2005, 09:51 AM
http://ls1tech.com/forums/showthread.php?t=384741
