Conversions & Hybrids - Air intake on a 94 3.4 l to ls1 swap
daddykamp
08-04-2005, 05:19 PM
Ive swaped out a 3.4 L v6 and put in a 97 ls1 out of a vette...it runs and drives great my only problem is the air intake...the mass air flow sensor is about 1 cm away from the radiator cover and i dont know what to do for an air intake. Anyone have any sugestions?
joking511
08-04-2005, 06:00 PM
You have to use an Lt1 setup. Unless you change the front clip to a 98 or newer .
daddykamp
08-04-2005, 06:09 PM
the problem is there isnt enough clearance between the maf and the radiator cover to stick an elbo in there...do u think maybe i should cut the radiator cover to where the elbo would have room?
joking511
08-04-2005, 06:13 PM
You need put the elbo on frist . Then the MAf
daddykamp
08-04-2005, 07:01 PM
alright thanks...ill do that :cheers: :hail:
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
