help with install please TB
ok tried searching but couldnt find anything so i'll ask here. i'm trying to install my p&p tb but i need to take the spring off the old one. is this possible? how hard is it? what kind of tool do i need to take the inside off. thanks
You need to remove the TPS sensor, and the two screws holding the throttle blade in. After you pull the throttle blade out, you should be able to pull the whole arm out of the throttle body.
