Forced Induction - HELP! About to buy a P-1SC How to visually inspect it?
ChevyChad
08-04-2005, 10:53 PM
I'm going this saturday to potentially buy a P-1SC from OKC (about a 2 hour drive from me). The seller never installed it on her car, and said it has maybe 36K miles from the previous owner. That mileage seems kindof high. Is there anything to worry about with that many miles on the blower? How can I visually inspect it to make sure it is in good condition? When I spin the impeller, should it make/ not make a certain noise? etc. Any input would be greatly appreciated before I spend a good chunk of change on it.
618HAWK
08-05-2005, 03:32 AM
I bought a used one a while back, need to look at the inlet blades for any major nicks or if there are wear marks along at the tips to case. There will be some slight play with in the gears if you hold he impeller and try and turn the drive this is normal. As for end play of the drive I would make sure there is not a lot. Pull the dip stick and see what the oil looks like if it is still there, and maybe the level if you can hold the unit in some what of the correct position with the dip stick screw at 12;00 position. Other wise there is not much else I can think of. When I bought my used head unit I sent it back to ATI for a inspection and resealing, just for good measures. I think it cost about 250-300 for a inspection and resealing. Money well spent in my eyes. You can take the serial # and call ATI and they can pull up the history on the unit as well to see if it has been in for any work and who has owned.
Chris
WAHUSKER
08-05-2005, 08:14 AM
ATI charges $75 just to crack it open & look at it. From there it depends on what needs replacing.
ChevyChad
08-05-2005, 08:15 AM
Thanks for the info. Not a bad idea to have ATI do the inspection too! Worst case, anyone know what that costs to have one rebuilt?
618HAWK
08-05-2005, 09:14 AM
I think it would depend on what needs to be replaced. I cant see it to be more than 1200.00, that is close to what they get for a P1 to D1 conversion???
Chris
ChevyChad
08-05-2005, 10:09 AM
I called ATI and they told me what to look for and worst case scenario, etc. You guys were dead on with your info. Thanks for the help. I feel better now knowing I'm prepared and know what to look for. :cheers:
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
