TNT Install
TNT Install
Ok, started installing a TNT F1 system. I've mounted the bottle and run the lines. Before I start connecting things I have one question. Which fittings need loctite / teflon paste and which don't? Thanks in advance!
AN fittings DO NOT use any sealant. Only use it on the NTP connections, and for those, use limited quantities.
In other words, if it hooks up to a nitrous line, no sealant.
If it going into the noid, then use a small amount. (You will see what I mean, if NPTside is flat while AN is flared.)
