Should I go from 150 to 200 shot?
Import Patrol
Well I must admitt I am hooked on the damn juice. I currently running the nx wet set up from 50-150 shot with a window switch from 3000-6000 what would it take to go from 150-200, can I just change the jet only or do I need to do more. If I could get away with just changing the jets what size jets should I put on it for the gas and n20. And do you think it would be a good idea to put a 200 shot with my current set up. Read the sig. I have the nitch to go to 200, but don't want to **** up my **** by doing so.
You can go to 200 just by changing jets, and if you can pull a few degrees of timing to be safe that would be even better. There was a guy on LS1.com that had a 200 shot on a stock fuel system and stock tune. I want to go to a 200 as well from my 150, im not gonna though till I can get power to hook to the ground a bit better.
Import Patrol
What size jets, and what is the best way to adjust the timming
I dont remember the jetting that the guy on LS1.com had but I am sure you can search here and find out or call NX and they can tell you. Timing can be pulled with tuning software like LS1 edit or HP tuners.
A 200 shot is a .082 N / .044 F jetting (nitrous/fuel). It may vary slightly from manufacturer to manufacturer but that will get you there safely with a single nozzle. I would also pull about 6 degrees of timing.
Import Patrol
I just want to make a pass or two on a 200 to see what the extra 50hp would do. The car is tunes already for the 150, do you think it would be to risky to bump it up to a 200 for a pass or two with out lowering my timming
If you already have timimg pulled then you should be ok with the 200, like I said there was a guy on the other site running a 200 wet shot on a stock tune/fuel system ands he said it worked great.
Originally Posted by GM Muscle
I would run 50/50 mix of pump gas and unleaded race gas to give you a nice cushion since your not sure where your timing is at.
