Throttle body bypass
Old 08-07-2005, 01:26 PM
Shutout's Avatar
Default Throttle body bypass
I live on Long Island and was wondering if the cold winters would cause my throttle body to freeze up if i did this mod? Is this mod worth the expense to switch back and forth from summer and winter if needed?
Old 08-07-2005, 01:44 PM
Redneck Z's Avatar
I don't think anyone has ever had one freeze up. People have done this mod in Alaska and not had a problem. I'd say go for it.
Old 08-07-2005, 01:49 PM
bolton98TA's Avatar
what exactly does this mod do?
Old 08-07-2005, 02:34 PM
TAQuickness's Avatar
this mod bypasses the coolant flow throught the intake. manufacturers do this to help steady the idle
Old 08-07-2005, 04:12 PM
RahuL's Avatar
Thumbs up
might gain upto 6 rwhp and 7 rwtq
Old 08-07-2005, 04:19 PM
Redneck Z's Avatar
The coolant normally flows through the TB(not intake). This heats the TB and keeps the butterfly from freezing(will never happen). This has nothing to do with steadying the idle as far as I know. Bypassing the tb keeps the tb/intake tract cooler and adds maybe 1-2rwhp if you are lucky...every little bit counts mod.
Old 08-07-2005, 04:25 PM
RahuL's Avatar
Originally Posted by Redneck Z
..Bypassing the tb keeps the tb/intake tract cooler and adds maybe 1-2rwhp if you are lucky...every little bit counts mod.
That's correct .... I was thinking about something else..
Old 08-07-2005, 04:30 PM
Magnet's Avatar
i was thkning about doing this too but i was wodnering if i need to buy a kit from someone or can i just go pick up the parts cheap somewhere? if so where can i buy them?
Old 08-07-2005, 04:35 PM
RahuL's Avatar
bmr has the kit...$16 bux ... link's on the right column =====>
Old 08-07-2005, 04:36 PM
Redneck Z's Avatar
Don't waste your money on the kit. Just pick up 2 feet of 5/16(i believe) fuel line from autozone and you're done.
Old 08-07-2005, 04:37 PM
-Q-
-Q-'s Avatar
5/16 is indeed correct. 2 hose clamps as well and you're good.
