A quick question about the exhaust crossmember
Did you guys leave it there after you installed your headers/y-pipe? Mine is still on there, but it's giving me hell with rattles, vibrations, and squeeking. Is there anything good to use to put in-between it and the Y-pipe to soak up these noises?
My Y pipe is 3.5 inch to a 4 inch I pipe out the back. Everything but the collecters is welded up with a few hangers. I get no bangs or rattles (that i can hear..) Being 3.5 inch, it's kind of low, but i have never scraped on any speedbump
crossmember is not there for the exhaust. If your exhaust were to move when you took it off, then your exhaust would need some work . Sounds like you have it covered now..
Dan
Dan
I put a couple thick washers between my cross over and floorpan, and that solved the problem right away, I actually didn't even have to put washers on both sides to make it stop. I wanted to keep my brace, I figured it must help even slightly at keeping th car from twisting.
Dan
Dan
Originally Posted by SiL3NtXWS6
Mine's been gone for over a year with TONS of hard launches. You can bend it with your hands, it's a piece of ****.
