HID Pic
http://www.hid-vision.com/catalog/
cheapie kit really, but it seems to work great from all i've seen. Kicking myself for not doing this sooner. A bit blue at night, but then my car is blue too, it's only a slight tinge.
I promise this will be my only 'ricer' mod.
Hey nothing rice about making your lights brighter so you can see where you're going at night. IMO I think the headlights on these cars suck for the most part. My '04 Impala is the same way. Not too bad, but nowhere near as bright as they should be. I miss the old sealed beams on my IROC. For some reason the always seemed alot brighter than the new(er) composite setups.
it's just a 9006 kit, with 6500K bulbs.
Kit comes with bulbs, ballasts, and ignitors, all the wiring (oddly, I had to wire mine in reverse, but hey)
Took about 40 mins to install, since we took our sweet time.
Some notes: 1. hook it up loose to test, if it works, find a place to ziptie, or place the components. Under the headlights worked great for the ignitors. Placed the other box near the upper fender.
*shocked* I promis to look away at the dirty engine bay this time!!! nice HID's by the way, i got a queation, i've searched and crap but still get a dead fish answer, is that only a one setting high beam thing? or is it a low/high beam setup? can you get some pix of it with out it being on? Thanks!
The people that I know who have bought similar kits only have low beams. In order to get lows and highs from the same bulb it nearly triples the cost. I think that if you were to get two seperate kits one for highs and one for lows depending on the projector the highs would be significantly brighter, obiviously. I will try to talk to some of the guys I know who have done this mod.
James
James
I knew you punks would gasp at the dirty engine bay, hey, got back from a trip to cali (roattrip)
Anywho, it's just normal lowbeams. If you turn your highbeams on, your outer lights turn off. I was pondering getting a 2nd highbeam kit (if they make it) then aiming them normal height, then using a relay which would run all 4 lamps at the same time.
