12" stall converter vs. 10" stall converter
Heard that the 10" inch converter is to small for the 4L60. Should stick with a 12" stall converter I guess.
When dealing with lockup is there an advantage to having a 12" or not?
Just heard some scary stories that some aftermarket converter companies use old 10" front wheel drive converters and remanufacture them into stall converters and sometimes use the original parts in them. Any truth to this.
Thanks
Thanks
well, from what i've read about most reputable converter makers is that they mahcine their's from forged or billet stocks. If you skimp on a converter and opt to get one from some cheap ebay seller, you may get one of those remachined ones. Spend the money for a good one. Its always worth it in the end.
