what acceseries with fast 90/90
Old 08-08-2005, 03:42 AM
shaulinmathvader's Avatar
Default what acceseries with fast 90/90
Might be planning a fast 90/90 setup. Do I have to buy with Tp sensor. is it necessary or do the stock ones work on it and what about the iac; Do I buy seals, rails . Any info on this would help. I know about the burst panel and still thinking about it. Does it already come with the necessary hardware to install. An also what about the nick williams 90MM TB from thunderracing? please help
Old 08-08-2005, 08:02 AM
Nick Williams's Avatar
You can use the stock IAC motor and TPS on my throttle body or the FAST. Just buy the intake and a throttle body and you will have everything you need. I would reccomend getting a set of new intake port seals. If you choose the FAST TB you will need a new bellows to fit it.
Nick
