Poly mounts installed...GOOD
Just installed the poly mounts. Really nice. With my cam and even new mounts..the thing shook like crazy, shifter looked like a vibrator when in neutral! Motor looked like a heart beating under the hood. Now...nothing. Nice. Small vibration in the steering wheel. Seems I lost even more traction but man the shifter and motor rock like a stocker and the car shakes less. Really nice. Pain to install though. The power transfer is instant as well. You gotta do it if you havent yet. Autozone sells them now.
Driver is easier, but make sure you disconnect your battery and if you have LT's they have to be taken out through the front near the alternator. FUN. Pull the alternator and its easier. Ac comp comes off for the other side. They were $19 each at autozone! I DO NOT reccomend the trans mount to be poly....it makes the worst driveline vibrations through the driveshaft tunnel. Feel great though. If anyone is near Ft. Lauderdale I can get them installed here for you. Good luck.
So far I've only replaced the trans mount with the Energy Suspension one and no vibrations at all. More info here.
https://ls1tech.com/forums/manual-transmission/364694-poly-transmission-mount-tips-impressions.html
Do you guys say you need to pull the alternator to get the long bolt out or is it to get the mount out? I was looking at it from under the car and the mount itself looks esay to slide out, but that bolt may not move all the way out without hitting the alternator. Maybe the alternator could be swung out of the way just a little? I plan on doing the drivers side then maybe the other if need be. Any tips would be appreciated.
https://ls1tech.com/forums/showthread.php?t=364694
