speakers by back passengers dont work!
hey guys i recently installed my alpine head unit in my camaro and i noticed that the 2 middle speakers (the ones by the back seats) dont work. they worked when i had the stock head unit in there, also it is a monsoon system i dont know if that helps. but if someone can help me out that would be great. thanks!
You would need to get a small amp to power those two speakers. The stock deck had an amp connected to it which the new deck doesn't have access to. My suggestion is get a 4 channel amp, wire the doors and the sides into it and let the rear two get powered by the deck...JMO
Ungrounded Moderator
If you decide to put in a different amp then you should replace the 2-ohm factory speakers as well (because of the odd impedance and because they can't handle much power).
