Hollow Crankshaft- Rear oil plug too far in??
Old 08-09-2005, 10:07 PM
soupnazi67's Avatar
Default Hollow Crankshaft- Rear oil plug too far in??
Uh,
I think I might have pushed the rear oil seal in the back of the crankshaft in too far trying to use the grease/hydraulic method to push out the pilot bearing. What do I need to do to fix this problem? I don't want to put my new clutch in only to find out my car is now pumping oil out all over the place!
Help!
Thanks,
Seth
Old 08-10-2005, 07:53 AM
Grimes's Avatar
If it's cocked and damaged, I'd remove it and then put in a new plug. If it still looks seated evenly, I'd just leave it though.
Old 04-19-2008, 02:42 AM
SUPERPOWERS's Avatar
where can I get a new plug. I did the same thing. Mine is cocked and damaged.
Old 04-19-2008, 07:44 AM
vettenuts's Avatar
I posted info on this the other day, hope this helps.
Link
Quick Reply: Hollow Crankshaft- Rear oil plug too far in??
