Oil Temperature Sender Install
What size drill bit and tap is needed to install the Autometer Oil Temp sender in the plate just above the oil filter?
Thanks
Bryan
parbreak
Thanks
Bryan
parbreak
I would think so. As long as you can thread that sender in there it will work.
By the way, in case anyone is interested the drill bit was 21/64" and the tap was 3/8" NPT. I'm pretty sure a 11/32" bit would work too but I spent an extra $3 to buy a cheap 21/64". Made for a very joint.
i have the z06 pan and that little housing where the oil pressure temp goes i can just swap them i believe they both come off i dont need the pan so i guess i should put a oil temp gauge in my car. How hot does the oil get ur your motor?
It seems like it takes a while to warm up. I took a drive today and it stayed at 185-190 for a while then went up to about 210-215. It was pretty hot here today, so not sure if that makes a big difference of not with oil temp.
