Dedicated Fuel system SPECIAL!!!!!!
Ok guys we are offering 50.00 off of our F-Body Non battery relocate dedicated fuel system.This system come complete with a custom built cell that mounts by the fuse box area,Walboro 340 Intank pump,Aeromotive Regulater(will flow high or low pressure),all fittings and hoses.
This system normally sells for 699.00.For the month of August it is 649.00
Here is a link to all the ones we offer.
http://www.nitrousoutlet.com/outlet/...section_id=122
PICTURE COMING SOON......
Thanks
Dave
Thanks
Dave
Originally Posted by jaypee1217
this might be a dumb question. But what are the benefits of a dedicated fuel system and low press vs. high press?
With a dedicated fuel system you can run regular pump gas in your gas tank and still a big shot. In the little tank just run some race gas. High pressure is for fuel injection, and low pressure is for carbs.
Thats what I have learned anyways.
I'm going to the track next weekend. Would it be beneficial to put 2-3 gallons of race gas in the tank for the juice? I've read that it doesnt really help you if you're running NA,but have never heard anything for the spray.
Jaypee....do a search on race gas an nitrous. There is alot of info out there. Or if you dont find what you want start a new thread on race gas on motor vs nitrous. Try to keep this thread about Daves badass fuel cells
I wish I didnt already have my ugly *** Jazz setup or I would have bought one of these. Makes it so damn easy and looks great.
Kleeborp the Moderator™
Oh, but I do have a tech question about this system...I'm guessing you can change the fuel pressure on this to alter your AFR when you are spraying. Now, since I have HPTuners and a Wideband, I can also tune my car to reach the desired AFR. So is it better to adjust the stand alone system to get the desired AFR, and have a tune that backs down the timing, OR just have a tune that backs down timing AND adds fuel (though the injectors)?
Originally Posted by MeentSS02
Dave, that's all I needed to know. So how much of an adjustment can you make with the fuel pressure alone? 0.5 AFR or so?
Dave
