my n2o install coming up soon
hi im new to this board. i have owned a few f bodys and have modded all them. i now have a 99 trans am with the a4. i have done hooker long tubes with hooker y pipe and slp loudmout, i also have a mti air lid and a bbk 85 mm throttle body and msd wires. i am wanting some advice on a good n2o kit to run, other mods i should do at the time of install, and recomended shot i should run. my car is all stock besides the mods i stated and it has 72k miles on it. thanks for your imput.
Im only familar with COLD FUSION, works great for me, im on a 125 shot, for you i'd do 100 (for starters) Obviosly the choice to go for a stock car is the Wet kit, upgrading your fuel pump is a must if you wanna go over 150shot, but a 100 should be fine with a stock setup. Good luck.
www.coldfusionnitrous.com tell'em you found it on ebay.
For the best quality and best customer service I suggest looking into a NX system.
We have a couple specials going this month you may like.
Make sure you change your spark plugs to NGK TR6s and get a window switch.I also suggest a bottle heater,purge,nitrous pressure gauge and fuel pressure safety switch.
You may look into a single nozzle kit and a GENX2 for your accessories.
Let me know if I can help in any way.
Dave
Dave
