Street Racing & Kill Stories Basic Technical Questions & Advice
Beat by SRT-4
Old 08-10-2005, 09:39 PM
Vendetta's Avatar
Default Beat by SRT-4
Comin home from work today, stopped next to an SRT-4. We went when the light dropped, and I outlaunched the hell out of him. He reeled me in through third though. Sounded like a catback and a BOV, probably not much more than that since he didn't pull me horribly bad. I actually expected it to be worse, I guess my launch save me from total embarassment.
Old 08-10-2005, 09:43 PM
CrabhartLS1's Avatar
in the WRX? wow yeah i'd expect that too. Although the stock exhausts on those things arn't all that restrictive. they pop and grumble like an angry, flatulant ape.
Old 08-10-2005, 09:50 PM
Vendetta's Avatar
It definitely could have been stock, he didn't pull me all that hard. It did have a BOV though.
Old 08-11-2005, 08:53 PM
GhettoTy's Avatar
He was prolly pretty much stock since the WRX's and SRT-4's are pretty close times wise. He might have a had a stage 1 kit.
Old 08-11-2005, 10:33 PM
Yeah they're probably pretty close. The SRT-4 is a little lighter, and has 230hp and 250ft. lbs. stock, compared to the 227hp and 217ft. lbs. of the stock WRX.
the WRX gets it to the ground better though. So i say that race ended up the way it should, a stock SRT-4 should be able to beat a WRX in a straight line.
Old 08-12-2005, 03:33 AM
Vendetta's Avatar
WRX gets it to the ground to all four wheels, but the drivetrain is a bitch to the power. Saps a lot by putting it to all four wheels.
Old 08-12-2005, 01:14 PM
wvutransam's Avatar
Exactly...
Dont NEONS with SRT badges come stock with a BOV?
Old 08-12-2005, 02:26 PM
SporkLover's Avatar
Originally Posted by wvutransam
Exactly...
Does this make you feel better about how well they run?
To answer your question, yes they do have a BOV. However it is environmental friendly, so it is internally vented. Meaning you dont get that BOV whistle when letting off the throttle.
How much does a WRX weigh? I know with it's thin paint and thin body panels it can't be too much more than an SRT-4. SRT's, depending on how they are optioned were between 2900-3000lbs.
Old 08-12-2005, 03:20 PM
Gloveperson's Avatar
Exhaust on the SRT4 is quite restrictive. If he had a BOV, they do nothing for performance, similar to how a WRX w/ a BOV does nothing but make the car run worse.
Old 08-12-2005, 05:34 PM
Vendetta's Avatar
BOVs do nothing for performance. I assumed that since he had an aftermarket atmospherical BOV, he probably had a few more bolt-ons.
WRXs weigh 3000-3100 lbs.
Old 08-12-2005, 05:55 PM
You'd be surprised at how dumb people are lol. The SRT's, WRX's, and EVO's around here have nothing but mods that do almost nothing for the money. Like, there is one kid with a WRX with a BOV and a CAI as his only mods.........
(not even an acufab or other boost controller....)
BTW, I love the quote in your sig
Old 08-12-2005, 06:13 PM
BlackSrt's Avatar
If he wasnt stock he would have pulled by you in 2nd gear....I bet you that he is 100% stock expect for the noise maker....I have ran many Wrx's and just annhilate them
Old 08-12-2005, 10:18 PM
METALBEAST's Avatar
Damnit Jon! Your not suppose to lose to near stock SRT-4s! You hurting the LT1 name. (Even though you weren't in an LT1, your THE LT1 moderator and that has to count for something )
Good death buddy!
Old 08-12-2005, 10:32 PM
exit's Avatar
BOV's protect the turbo more then anything else...
they do help "performance" in the sense they they make the turbo's job easyer when the throttle body plate closes....
Old 08-12-2005, 10:43 PM
Import Patrol
CrawlinWS6's Avatar
time to trade in the wrx for a f-body. Thats my opinion
Old 08-12-2005, 11:10 PM
METALBEAST's Avatar
He's working on it
Old 08-12-2005, 11:47 PM
they make WRX's run worse
Old 08-14-2005, 10:09 AM
GXPPOWER's Avatar
srt4 have no mufflers and their exhausts are very free flowing.
they are very fast up top.
Old 08-14-2005, 10:31 AM
SporkLover's Avatar
The pieces from the cat back are relativelyfree flowing, but everything from exhaust manifolds to the downpipe are really restrictive. The turbo is a 16g stuffed into a td04 housing... which really needs a td05.... the o2 housing on the turbo is extremely restrictive, just replacing that people have picked up 5 whp. The down pipe has a 2.5 outside diameter, but close to a 2.2 inch inside diameter.
The SRT already has a BOV stock... the WRX already has a BOV stock...it's just that they are internally vented so there is no whoosh or whistle noise.... ricers dont like quiet. There is no need for an external one unless you are close to exceeding the stock rating. SRT's need them replaced if exceeding 18psi of boost.
Old 08-14-2005, 12:16 PM
Vendetta's Avatar
I'm tryin man, I'm tryin... I just happen to be uber picky about my cars and haven't found the right one yet.
Good death buddy!
