Installing Dynotune Purge Kit on TNT F1
I'm looking to install a dynotune purge solenoid with a TNT F1 Kit. Anyone else done this? Where did you put the purge solenoid? I assume you need to buy another section of braided line to go from the purge solenoid the the TNT nitrous solenoid right? Thanks!
Well what we use is a #3 line that runs from the purge manifold to the purge sol, so that it can be mounted remotely.. Unless you have our new mounting bracket its going to be hard to fit the manifold/sol tog.. Just remove the 1/8pipe union and replace it with #3 fittings and add a #3 line.. Hope that helps ya out, David@TNT..
Originally Posted by David@TNT
Well you definately made it work Jaypee.. Thats our old style bracket, our new style is much easier to deal with.. David@TNT
rick
Originally Posted by TNTramair
when did the new bracket come out?? and whats it look like??...cause i bought a F2 kit back in october 04 and i had a mother of a time with that damn thing tryin to get everything to fit properly. so im wondering if it was allready the new bracket or still an old one. thanx
rick
rick
The new bracket came out around Mar 05, so you have the old style.. The biggest diff in looks is the channels that allow the sol to pivot front to back.. Thanks David@TNT
just get an extra 3ft -4an line, the way mine sits, the nitrous line already rests against the heater hose. unless you do something like jaypee did and have the bracket bowed out.
Originally Posted by jaypee1217
I too have the dynotune purge w/ a TNT kit. Here's a pic. Sorry its not a close up shot but you can see the purge solenoid.
Ok, I started to put the solenoid on only to realize the fitting is to small on the Dynotune solenoid to screw into the TNT nitrous solenoid. Also, the main feed line fitting is too big for the Dynotune fitting. Is the TNT a 6AN line/fitting? Or am I missing something? The purge solenoid should screw right into the TNT nitrous solenoid and you connect the main nitrous line to the purge solenoid right? Thanks in advance!
I tried mounting mine at the nitrous solenoid but it was a mess. I said screw it and put the noid at the cowl with and an 18" line after it. Still hits super hard and super clean.
Originally Posted by hourang
the tnt f1 is a -4an main feed line. the dynotune purge kit only comes in -4 and -6. so the only way the tnt line is bigger is if you have a -6an on the tnt kit, is it a used kit? can you post a pic?
It's definitely a 6AN fitting. I called TNT just to make sure I wasn't insane and they confirmed that the main feed line now comes with 6AN fittings...hmmm...guess I shouldn't checked on that before buying components...that's what happens when you assume
