Bassani TD's
i have that... the stupid shop i took it to welded the ******* headers to the existing pipes going to the x pipe.
but in a proper fix, you should use 3 inch to 2.5 inch reducers, and clamp them on, and you will have to cut the drives side pipe and i think modify the passenger side pipe a little....
needless to say i am going to have to go to a shop and have them fix the shitty work on htere... but it is doable
i modified it to fit the bassani headers with cats. anything is doable. vinci modified it to fit a set of MAC with cats.
https://ls1tech.com/forums/showthrea...hlight=bassani
pics of when vinci put the bassani on MAC headers in this thread
not sure about ground clearance, but bassani does have BAD *** cats available... they are designed great
when i have my exhaust fixed i'm going to put cut outs on as well
Originally Posted by mrr23
i have the newer design metalicats from bassani on her car as well. 2.5" round design.
Is the catalyst material in this actually a metal of some sort? Does it do anything for emissions, or just smooth out the sound?
Thanks for the input as of now i am planning on buying the system and then buy long tubes later down the road. Is there a problem with the exhaust hiting the PHB. Is there any banging noises that comes from the system. Thanks
Originally Posted by White_TA_27
also i noticed this system is for 00-02 cars, will I have much of a problem making it work on my 98 TA
