Meziere vs Stock
Don't think the Meziere in and of itself is going to lower temps. That's more a function of the thermostat and your fan setting. The difference between the race and street versions is that the street version has a provision for the heater hoses while the race version does not.
Bryan
parbreak
Bryan
parbreak
In stop and go traffic it runs a lot cooler due to higher flow at low rpm. And slightly cooler on the highway. The thermostat will turn the water flow on at a cooler temp but they will still rise over its rated temp. More flow through the radiator equals more heat exchange. As does a bigger more efficient radiator.
Of Course The Water Pump Lowers The Temps! It Also Comes With A 160 Thermostat. How Do You Think You Get Extra Hp! The Pump Is Making The Car Run Cooler, Freeing Up Horse Power! A Cooler Car Is More Powerful Than A Hot Car!! So In Anwser To The Question An Electric Water Pump Has Been Proven To Increase Hp By Decreasing Engine Temp! I Have A Race Pump For Sale For 300 Shiped! Brand New In The Box
Mine came with no thermostat, so did the 2nd and 3rd one i bought. There is also a parasitical loss from the stock pump from drag. This is also how it boosts hp, along with cooler temps.
