View Poll Results: Which would you use and why?
918s
18
56.25%
Gold .650"
14
43.75%
Voters: 32. You may not vote on this poll
So which would you use then? 918 vs Golds...
I used the 918's on a 224/220 .581/.581 for 10K+ with outstanding results.
The only reason I changed is because I swapped heads and they came with duals.
If you are keeping your stock lifters, 918's will be more merciful on them + lighter valve train and a few more ponies too.
This thread should help your descision
https://ls1tech.com/forums/generation-iii-internal-engine/364195-will-918-springs-work-g5x4-cam-thanks.html
