patriot springs
patriot springs
I got a used set of patriot dual springs from this board last week. they are going on my car tonight. I need to know if I NEED anything else to make them work. i have the dual springs with locks, retainers and valve seats(dark grey things that look like smaller retainers.
read my post #13 somewhere on the bottom, and reffer to the picture that I posted.
That's basicaly a whole kit right there
https://ls1tech.com/forums/generation-iii-internal-engine/350467-need-help-changing-out-valvesprings.html
for inquireing minds you can use the stock seats with the duals. my springs sit flay on the seats. now I just need to make sure I actually have a g5x3, there is nothing written on it.
Not sure how you got to the conclusion it's OK to reuse stock seats w/ aftermarket springs, but if it's been proven to work and the manufacturer says it's OK then it's a step saved.
well here is my problem, I don't have seals and I need to have my cam by tommorow. can I use the stock seats and seals with the gold springs or can i resuse the stock seals?
That is the equivalent of trying to do 1/4 (404 meters) and stopping at 399.
Get seals and change them.
and if you want sound advice, get yourself a set of 850-16 Comp Cam lifters and replace those too.
Then you can say I did a complete H/C swap and it rocks.
