Engine Wont Start
Old 08-13-2005, 08:08 PM
intensity's Avatar
Default Engine Wont Start
I have a 83 ford ranger 2.2l diesel with unknown miles that lost coolant and overheated it died and will not start. When i turn it over it turns very smoothly like there is no compression. There is no water in the oil (but it lost coolant anyway).
Old 08-13-2005, 08:19 PM
goober35's Avatar
Did it die when it was running or did you turn it off and then it just will not start now.
Old 08-13-2005, 08:41 PM
intensity's Avatar
It died while driving down the freeway (no sputtering). It also would not turnover at first and as it cooled down it turned over.
Old 08-13-2005, 08:50 PM
goober35's Avatar
Umm well i thing the motor might just be a paper wait now. If there is no compretion there will be no way for the motor to run sence diesel runs on compretion. You might have melted the piston rings.
Do a compretion test to make sure.
Old 08-13-2005, 09:06 PM
intensity's Avatar
How do you do a compresion test.
Old 08-13-2005, 09:17 PM
goober35's Avatar
Go down the your autopart store and ask them for there compretion kit tester.
Old 08-14-2005, 03:41 PM
intensity's Avatar
If no compression is it dead or a blown head gasget
Old 08-14-2005, 03:46 PM
goober35's Avatar
I am going to bet on something other than a blow head gasket. But it still could be but you whould have to have blowen it on each cyclender.
