Pushrod length sanity check
Old 08-13-2005, 11:03 PM
mr2guru's Avatar
Default Pushrod length sanity check
Check my research...
225 AFRs unmilled
.043 compressed gaskets
stock rockers/lifters
.030 smaller base circle cam
I come up with 7.401 Sound right?
Old 08-13-2005, 11:26 PM
strokedls1's Avatar
I would do a 7.350 with that combo. Stock is a 7.400 with a .052 gasket. If your .030 under on the cam and .009 on the gasket then the small 7.350 would be close enough for stock lifters.
Old 08-13-2005, 11:56 PM
mr2guru's Avatar
Interesting...my stockers measured 7.375 (7.38) on my dial caliper.
Old 08-14-2005, 01:10 AM
strokedls1's Avatar
Well then .039 decrease in head and gasket =7.375-.039=7.336 Seems like the 7.350 would work fine.
Old 08-14-2005, 03:58 AM
PREDATOR-Z's Avatar
225 AFRs unmilled
Yeap that is correct 7.40 p-rods is what you need.
Calcs:
7.38+0.030=7.410
7.410-0.009= 7.401
> 7.40 are your p-rod length needed.
