Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Power steering pulley tool Questions?
Old 08-14-2005, 09:26 AM
LS1FIRE's Avatar
Default Power steering pulley tool Questions?
Hello i am looking for a power steering puller/pusher to uninstall and reinstall a new PS pulley on my Powersteering pump. Is there a special tool needed for our cars? Does anybody know a place were i can order one online? Also does anyone have picutures on what the tool is sopose to look like. I went searching around some part stores but couldnt find one. I only find a 2 jaw puller type that only can be used to remove the pulley. http://www.partsamerica.com/ProductD...tnumber=648460
I only found this one at the local part stores.
Thank you very much.
Old 08-14-2005, 10:13 AM
stevieturbo's Avatar
I bought this one from Summit, although I havent used it yet.
SUM-W87022
Old 08-14-2005, 10:22 AM
LS1FIRE's Avatar
SUM-W87022
Thanks for the Part number.
Old 08-14-2005, 10:23 AM
LS1FIRE's Avatar
Can somone confirm if this tool will work from summit before i order it?
Thanks
Old 08-14-2005, 10:35 AM
I'll go take a look at it now. Its actually still in the packet.
Old 08-14-2005, 10:47 AM
I'd say it will work fine....
For the installer, you may need to cut of the 5/16" UNC thread section at the end.. The thread inside my PAS pump is 3/8" UNC, so I'd need to do the same
See pic enclosed of all the parts.
Old 08-15-2005, 04:52 AM
LS1FIRE's Avatar
Thank you very much for the helpful reply. What do you mean cut of the 5/16" UNC thread section? I am sorry i am not sure what you mean. Do you have a close up pick were you mean cut? I will be doing the install. I Thank you very much for your help and time.
Old 08-15-2005, 05:06 AM
LS1FIRE's Avatar
Does anybody else know a place were i can order a tool that will work without modifications?
Old 08-15-2005, 05:49 AM
SUPRYZE's Avatar
Its real cheap, but appears very similar to the one I purchased from MAC Tools:
http://www.harborfreight.com/cpi/cta...emnumber=40749
Once the tool is installed, pulley removal will look like this:
Old 08-15-2005, 06:58 AM
Left hand item in the picture.
It is threaded 3/8" for most of its length. The tip however is only 5/16". This will not screw into the threads in the PAS pump, as the pump is 3/8"UNC
These are the threads used for pulling the pulley onto its shaft.
Old 08-15-2005, 07:41 AM
LS1FIRE's Avatar
i orderd the tool from harbor freight I hope it works good.
Thanks yall
Quick Reply: Power steering pulley tool Questions?
