PCV valve question?
PCV valve question?
Can it cause a your car to surge froma vaccum leak? I replaced the valve right before the H/C install with an Autosone valve. Do I need to buy one from GM or will the one from Autozone work?
not sure on the autozone piece but if im not mistaken; a pcv valve is a um....well, a valve. If it doesnt work, meaning it is not opening it wont cause a leak.
MAybe you already know this but this is the first thing that comes to mind...
good luck!!!
good luck!!!
