Can't use MLS Gaskets on 1998 LS1 Heads???
I read on a website that I can not use MLS gaskets on 98 LS1 Heads.
"These early heads are unique because they had a recessed area right below the No. 3 or No. 6 cylinder, so rebuilders must use the early style, composition head gaskets with them. If the later MLS gaskets are installed with the heads that have the recess, the engine will leak coolant to the outside from the recessed area in the deck surface."
I dont know how old this is, but does anyone make MLS gaskets that work with 98 heads? If not then what gasket should with hold with a H/C 347 with a 250 shot? I plan on running ARP head studs.
Super Moderator
That is correct. You want to use the gasket for that year model heads. If you look at the heads, they are notched out along the lower edge of the head and if you use the GM MLS gaskets they will not seal there and you will leak coolant.
You can however use an aftermarket MLS gasket such as the Cometic I believe.
Originally Posted by ws.6kid
Um so any aftermarket MLS gasket will work just not the GM one?
Originally Posted by ArcticZ28
If you're going to go with MLS, go with Cometics and spray each side with copper spray sealant. That will seal up any small imperfections that may cause leakage.
Originally Posted by 777
I thought they were supposed to be used dry?
the issue in question is not a small imperfection, it is a "notch" that is part of the casting, while copper sealant might work, if would be iffy.
the MLS gaskets should not be used for the reason stated above, we cure the whole issue by welding up the notch and then milling the head, end up only doing a slight resurface of like .002
Yah you need to weld and resurface the deck. Then you can use a 98 specific head gasket. My friends 98 is where cometic learned the design issue of differences in the head from 99+. Cheaper and easier to just use a stock gasket unless your looking for the extra compression and quench from a mls.
Well my whole issue is being able to spray a 250 shot, I figured stock head gaskets would not cut it, even with arp head studs. What gasket is safe to run with a 250 shot on top of 450 rwhp??
