.040 Cometic.... .033 quench too tight?
Old 08-15-2005, 11:07 AM
John02SS's Avatar
Default .040 Cometic.... .033 quench too tight?
After hours of searching for the biggest cam that would fit I've decided the hell with it and I'll be flycutting. Heads are TEA 2.5 LS6's and cam will be MS3 or G5X4. Wanna keep the compression over 11 so I'll have to go alittle thinner on the gaskets with the material being taken out on the pistons. Heads are milled .010. I've seen threads were .035-.040 was ideal quench, but seen several running the .040 gasket. What are your thoughts on the tighter quench?
John
Old 08-15-2005, 11:12 AM
WS6FirebirdTA00's Avatar
from what i was told, cant remember who told me on here, but 0.033-0.035 is for race and 0.035-0.038 is street.
Old 08-15-2005, 05:44 PM
smask04C5's Avatar
I've got .040 cometics with pistons out .006 and my quench is fine on a stock bottom end. I will say that engine will see no more than 6300 rpm, with my cam, no reason to go any tighter.
Old 08-15-2005, 06:33 PM
tonyb's Avatar
I run .040 Cometics with pistons .010 out of the hole.Street hard driven with no worries.
Anthony
Old 08-15-2005, 07:45 PM
DanZ28's Avatar
.027" Cometics, but .008" in the hole
You could always go right in the middle using a .043" Cometic to put you at .036" quench.
Old 08-15-2005, 09:46 PM
John02SS's Avatar
How high are you fellas spinning them? I'll be looking at 6800 shiftpoints more than likely. Spoke to Jason at TSP and he is all for the .040 so with the info from you guys that is probably the direction I'll head, assuming I can find the things! Keep the input coming! I do appreciate it.
John
Old 08-15-2005, 10:44 PM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
I've run .040" on quite a few cars. I -think- I've even run .030" before (.023" quench cold) but wouldn't recommend it for most sane ppl.
Old 08-15-2005, 10:48 PM
John02SS's Avatar
lol........023 is close! I'll be calling the shop tomorrow Joseph to order up some parts. Round me up a fly cutter to rent! Jon said you guys are out of the rentals, so I'll have to buy one if not. Thanks buddy!
John
Old 08-15-2005, 11:00 PM
-Joseph-'s Avatar
I may be able to find enough cutters to piece a kit together. Although to do it the right way you'd need a core head with the valve seats cut out for the cutter to cut at the right spot.
Old 08-16-2005, 09:14 AM
BrentB@TEA's Avatar
also consider as the engine warms up your quench will grow. (aluminum block expanding)
You will be fine with a .040
Old 08-17-2005, 12:26 AM
Restricted User
CAT3's Avatar
I have 40's, havent run it yet, but was told when I asked on here, to let the engine warm up as Brent mentioned before getting on it.
Old 08-17-2005, 02:07 PM
Spinmonster's Avatar
.027 .007 out of the hole...forged rotating assembly
and I spin to 7100. 8k on this set-up and I punish this car...N2O too
Old 08-17-2005, 02:37 PM
John02SS's Avatar
That is what I wanted to hear fellas! the .040's are on the way! **** they were hard to find!
Old 08-17-2005, 05:14 PM
z-ya's Avatar
.036 cometics on a stock short block,pistons .010 out the hole no problems.
Quick Reply: .040 Cometic.... .033 quench too tight?
