Ryne @ CMS
08-16-2005, 03:37 PM
93 383 LT1 Trans Am
Mod list:
383 Splayed four bolt block
scat forged crank
Lunati Sportman Rods 5.825 length
CP nitrous pistons
AFR 195 Comp Port heads
comp 306 cam, 230 and 244 @ .050 lift, 510 int 540 ext, on a 112 lsa
crane 1.6 rockers
Port Matched LT4 Manifold
DTE billet Opti-spark otherwise known as the Dynaspark
electric water pump
be cool radiator
custom fuel system with -10 feed lines -6 return lines
ricks hot rod custom fuel tank with brand new Aeromotive A1000 pump mounted in tank, ( tank not yet installed)
center force dual friction clutch
B&M Ripper shifter
NX nitrous set up, with two shark nozzles mounted in the elbow
BBK 58 MM throttle Body
hooker long tubes
off-road y pipe
your choice of exhausts i have many that fit this car
QA1 adjustable Shocks all the way around
eibach Drag launch springs, or eibach Sport line springs
Zr1 rims chrome 17x9.5 and 17x11
Wilwood big brake kit up front
Moser 12 bolt with 4:10's
inland empire drive shaft 3.5 inch drive shaft
driveshaft loop
wolfe six point roll bar
custom subframe connectors
corbeau Carrera seats, with harnesses
motor was built by morgan motorsport about three years ago, has about 10,000 miles on it, car has about 42,000 miles on it, has not been driven for about year and a half, due to fuel tank issue, now i have new fuel tank for it, but dont have time to install, nor do i have the space. motor dyno 436 rwhp , 414 rwtq, computer has been converted over to a 94 computer with associated harness. car does not run right due to tank not being in it, but the tank will go with the car. this car set up for drag racing so it doesnt have a/c in it. this car is done and is ready do go, just needs a little TLC before it goes to the track.
sell as is for 12,000 dollars doesnt need much to run
everything included
Mod list:
scat forged crank
CP nitrous pistons
crane 1.6 rockers
electric water pump
be cool radiator
B&M Ripper shifter
hooker long tubes
off-road y pipe
driveshaft loop
everything included
